Breeding a Mythological monstrosity in My Singing Monsters is a ritual of passage for every consecrate player. If you have been marvel how to breed G'joob, you are certainly not alone; this elusive creature is a favorite among collectors for its unique appearance and soothing cello-like sounds. Find this monstrosity involve longanimity, strategy, and a bit of luck, as it is not as straightforward as breed mutual behemoth. By understanding the specific mechanics of the Plant Island and the optimum giant combinations, you can importantly growth your fortune of impart this legendary fauna to your collection. This guide will walk you through every step of the process to ensure you win in your fostering endeavors.
Understanding the G’joob
The G' joob is a Mythological colossus that resides primarily on Plant Island. It is cognise for its walrus-like tusk and the musical cat's-paw it carries, which provides a deep, melodic bass line to your island's song. Unlike standard monsters, Mythical wight like G' joob have lower cover success rate, get the breed combination and your apparatus crucial for success.
Recommended Breeding Combination
To maximize your odds, you must use the correct parent freak. The game logic relies on specific elemental combination, and for the G' joob, you are required to use:
- T-Rox (Land, Cold, Water)
- Bowgart (Plant, Cold, Water)
When you combine these two monsters, you are efficaciously desegregate the elements of Plant, Earth, Cold, and Water. Because G'joob is a Mythical goliath, it is consider a "special" breed, entail it does not have a 100 % success rate.
| Monster | Ingredient | Use |
| T-Rox | Earth, Cold, Water | Parent A |
| Bowgart | Works, Cold, Water | Parent B |
Optimizing Your Breeding Success
Even with the correct pairing, success isn't guaranteed on the first endeavour. Many players find themselves breeding gobs of clip before the G' joob appears. Hither are the most effective ways to advance your chances:
Leveling Up Your Monsters
It is a well-documented community scheme that higher-level giant have a best fortune of producing rare and fabulous outcomes. Aim to get both your T-Rox and Bowgart to at least plane 10 or higher. This consumes more nutrient, but it drastically improves your breeding odds.
Using Wishing Torches
Wishing Torch are essential for high-rarity upbringing. Perch all ten flashlight on your island provides a significant boost to your cover success pace. If you are scramble to get the G' joob, ask ally to light your torches or spend diamonds to light them yourself before assay the breed.
💡 Note: The breeding time for a successful G'joob attempt is 18 hours on a veritable breeding construction, or 13 hours and 30 proceedings if you have an enhanced breeding structure.
Step-by-Step Breeding Process
- Ensure your Breeding Construction on Plant Island is vacuous.
- Select the T-Rox as your inaugural behemoth.
- Take the Bowgart as your second monster.
- Click "Breed" and waiting for the indicated time.
- If you see a time other than 18 hour (or 13.5 hours), you have likely cover another T-Rox or Bowgart; try again!
Achieving success with this Mythological monster is solely qualified on continuity. By utilizing the T-Rox and Bowgart combination, ensuring your parent monster are leveled up, and maximise the use of lit wish flashlight, you position yourself for the better potential result. Do not get discouraged if it takes multiple effort, as the reward of having this iconic colossus on your island is good worth the effort and resources spent during the process. Proceed your breeding structure meddling, manage your resources sagely, and you will eventually see the G' joob egg ready to concoct in your greenhouse.
- better way to breed g'joob
- how to breed yool
- best way to get g'joob
- how to breed epic g'joob
- my vocalizing giant g'joob strain
- Related searches g'joob rearing time
