How To Uninstall Valorant
Whether you are looking to regenerate store infinite on your hard campaign, troubleshoot relentless technical glitches, or simply take a break from the competitive intensity of the game, learning how to uninstall Valorant is a aboveboard summons. As a game that apply the rich Riot Vanguard anti-cheat system, it is not always as simple as deleting a leaflet; you must assure that all components, include the anti-cheat package, are totally removed to preserve scheme constancy. This usher will walk you through the crucial steps to clean up your system efficiently and effectively.
Understanding the Valorant Uninstallation Process
Valorant consists of two primary components: the game customer itself and the Riot Vanguard anti-cheat driver. Because Vanguard operate at the core level, it is deeply incorporate into your Windows surroundings. If you merely take the game launcher but leave the anti-cheat driver behind, you may encounter system performance issues or leftover background service. Proper uninstallation ensures that your PC remain optimized and gratis of superfluous file.
Step 1: Closing Background Processes
Before initiating the uninstallation, control that the game and the Riot Client are not running. Check your system tray (bottom rightfield nook of your taskbar), right-click the Riot Vanguard icon, and take Exit Vanguard if necessary. If the process is stubborn, open the Task Manager (Ctrl + Shift + Esc) and terminate any tasks labeled "Valorant" or "Riot Client."
Step 2: Removing the Game via Windows Settings
The standard way to withdraw any software is through the Windows Settings menu. Follow these step:
  • Open the Start Menu and click the gear ikon to open Scope.
  • Navigate to Apps, then select Installed Apps or Apps & characteristic.
  • In the search bar, eccentric "Valorant."
  • Click on the three dit next to the covering and select Uninstall.
Step 3: Uninstalling Riot Vanguard
Even after remove Valorant, the Vanguard package ofttimes stay on your system as a standalone debut. To remove it:
  • Return to the Apps & lineament carte in your setting.
  • Hunt for Riot Vanguard.
  • Click Uninstall and support the prompt. This is crucial for a clean removal.
Comparison of Removal Methods
Method Efficiency Relief of Use
Windows Settings Eminent Easy
Control Panel High Moderate
Third-Party Uninstaller Very Eminent Easy (but risky)
💡 Note: If you meet an mistake express that the file is in use, restart your estimator before undertake the uninstallation again. This clears any loaf scheme whorl on the Vanguard driver.
Clearing Leftover Files
Sometimes, temporary folders remain yet after the main installation is gone. You can manually check your local file to ensure full deletion:
  • Insistency Win + R on your keyboard and type%localappdata%.
  • Locate the Riot Games folder.
  • Delete the content touch to Valorant and the Riot Client.
  • Ensure you vacate your Recycle Bin subsequently to permanently brighten the space from your hard drive.
Usually, uninstalling the independent game does not withdraw the Vanguard anti-cheat service mechanically. You must uninstall "Riot Vanguard" as a freestanding coating from your Windows settings to insure it is whole take.
Yes. All your account advancement, skins, and rank datum are store on Riot's host, not topically on your PC. You can safely uninstall and log back in later to find everything exactly as you left it.
Yes, you can. Nonetheless, Vanguard is contrive to commence when you reboot your reckoner. If you happen it interferes with other package, you can handicap it, but you will want to restart your computer to enable it again before you can play Valorant.
Successfully withdraw the game requires attending to both the Riot Client and the Vanguard anti-cheat driver to prevent system clutter. By utilise the built-in Windows uninstallation creature and do a quick manual check of your local app data, you ascertain that no residuary file remain to affect your figurer's execution. Following these structured steps guarantee a clean environment, providing you with the tractability to deal your installed applications effectively whenever the need arises.
  • how to cancel valorant download
  • how to permanently delete valorant
  • remove valorant completely
  • how to delete valorant fully
  • valorant delete game
  • how to erase valorant pc
