How To Use Artinya
How To Use Artinya
Language erudition can oft sense like navigating a complex labyrinth, peculiarly when you encounter terms that bridge the gap between two different linguistic worlds. If you are learning Indonesian or interacting with Indonesian speakers, you will frequently arrive across the tidings "artinya". Interpret how to use artinya correctly is a foundational step in mastering conversational Indonesian and better your rendering skills. By definition, "artinya" translate to "mean" or "it means", serve as a critical span when you require to clarify a news, phrase, or concept. Whether you are a beginner looking to clarify vocabulary or an medium assimilator aiming for more nuanced communicating, master this term will significantly advance your volubility.
Understanding the Role of Artinya
The word "artinya" is infer from the rootage word arti (meaning) combined with the suffix -nya (possessive/definite marker). In a real sensation, it go as "its meaning." However, in literal exercise, it is fabulously versatile. It act as a bridge to explain definitions, express the significance of a situation, or merely elucidate what individual just aver.
Common Contexts for Usage
There are three principal ways you will find yourself using this term in everyday conversations:
  • Clarification: Ask what a specific tidings or sentence means.
  • Account: Providing the definition or the deduction of a idiom.
  • Conceptual Rendering: Describing the deeper implication of an action or case.
Step-by-Step Guide: How To Use Artinya
To use this condition efficaciously, you need to understand the grammatical construction. It is seldom utilize in isolation; it unremarkably requires a subject or a acknowledgment point to be effective.
Asking for Meaning
When you learn a news you do not spot, you can ask for the meaning by framing it as a enquiry. For example, if you want to cognise what "makan" means, you say: "Apa artinya makan?" This construction is world-wide for vocabulary building.
Providing a Definition
When you are the one explaining, you can use the word as a argument. If someone asks you about a ethnical term, you might reply with: "Artinya adalah…" (The signification is…). This assist in open communication by point that a definition postdate.
Position Sample Phrase English Version
Asking for word definition Apa artinya 'buku '? What is the signification of 'book '?
Explaining a concept Artinya, kita harus pergi. It means, we have to go.
Sum an outcome Itu artinya kita menang. That intend we won.
💡 Note: When using "artinya" in formal authorship, ascertain that the subject being define is open, as the suffix "-nya" implies that you are touch to something previously mentioned in the conversation.
Expanding Your Fluency with LSI Keywords
To master this term, you should also become conversant with related lingual price like definisi (definition), makna (significance/meaning), and maksud (purpose). While "artinya" is used for unmediated version or clarifying language, "maksud" is oftentimes utilize to ask for the intent behind an activity or argument. Mixing these fitly will get your Indonesian sound much more aboriginal and professional.
No, it can be use for entire sentence or still conceptual ideas to explain the fundamental entailment of a argument.
"Artinya" focuses on the lexical meaning or definition of a word/phrase, whereas "maksudnya" concentre on the intention or aim behind what someone allege.
Yes, it is perfectly acceptable in professional contexts when you need to clarify a condition or delimit a technological conception for a colleague.
Mastering how to use artinya supply you with the essential creature to sail words roadblock and assure limpidity in your communication. By practicing the structure of asking for definitions and providing them in return, you transition from but learn lyric to truly understanding how to convey information effectively in Indonesian. Starting by incorporating this condition into your day-to-day practice, and you will soon find that your power to parse substance and explain your thoughts ameliorate drastically. Consistency and circumstance are your best allies, so keep listening for how aboriginal verbaliser use this various term to bridge gaps in understanding during everyday interactions. As you go more comfortable, you will notice that communicating becomes much politic, allowing you to concentrate on the content of your message rather than worrying about potential misunderstandings.
  • use bahasa inggris
  • use artinya bahasa indonesia
  • penggunaan dalam bahasa indonesia
  • use artinya di kamus
  • use significance in indonesia
  • use dalam bahasa indonesia
