Zebrawood, scientifically cognize as Microberlinia brazzavillensis, is a striking lumber species extremely essay after by fine furniture makers and interior designers for its distinctive dark, wavy streaks that resemble the coat of a zebra. When considering this forest for expression or cabinetwork projects, the weight of zebrawood is a essential component for artisans to translate. As a dense, alien hardwood, its physical place importantly determine not merely the structural unity of a finished piece but also the logistics of transport and the difficulty of machining the raw textile. Read this density helps in figure load-bearing requisite, take appropriate cabinetmaking technique, and managing creature wear during the shaping summons.
Physical Characteristics and Density
To truly grasp the impingement of the weight of zebrawood, one must look at its concentration profile. Generally categorise as a heavy and difficult woods, it cater a tactile sensation of quality and durability that is absent in softer, fast-growing domestic woods. The concentration of forest direct correlate to its cellular structure, which in this case is tightly packed and interlocking, lend to its notable resistance to wear.
Understanding Janka Hardness and Density
The weight and concentration of timber are often dissect alongside the Janka callosity scale. While hardness amount opposition to indentation, the overall weight is a function of the wood's specific sobriety. Zebrawood typically exhibits a specific gravity ranging from 0.65 to 0.75, which places it firmly in the family of heavy hardwoods.
- Strength: High density assure that furniture pieces are less prone to rise scratch.
- Constancy: While heavy, it can be susceptible to move if not properly dried.
- Workability: Because of its high weight and interlocking cereal, it requires sharp, high-quality carbide-tipped creature.
| Property | Typical Value |
| Average Dry Weight | ~45-50 lbs/ft³ (720-800 kg/m³) |
| Janka Hardness | ~1,570 lbf (6,980 N) |
| Specific Gravity | 0.65 - 0.75 |
Machining and Handling Challenges
The physical spate of this lumber demo unique challenges during the carpentry summons. When act with real slab, the weight of zebrawood can be physically ask. Moreover, the interlocking grain, which gives the forest its aesthetic appeal, makes it prone to tear-out when planing or routing.
⚠️ Note: Always use sharp, high-speed steel or carbide-tipped blades when slew, as the high concentration of this wood accelerates tool dulling importantly liken to softer coinage like pine or cedarwood.
Structural Considerations for Furniture Design
Because of the inherent weight of zebrawood, designers must be mindful of the "dead load" of the furniture itself. If a table or locker is built entirely from thick-dimensioned zebrawood, the outcome can be exceptionally heavy. This requires careful condition of structural supports, flooring lading capability, and the necessity of castor or reward leg to negociate the stress over clip.
Comparison with Other Exotic Hardwoods
When comparing zebrawood to other democratic exotic choice like Wenge or Rosewood, its weight profile is moderate but real. Wenge, for example, is much denser and heavy, create zebrawood a somewhat more manageable, though nevertheless taxing, material for large-scale labor.
Density and Acoustic Properties
The concentration and weight also conduce to the acoustical characteristics of the forest. In cat's-paw qualification, the weight of zebrawood provides a brilliant, nipping timber with excellent sustain, making it a favorite for guitar bodies and ornamental accent on high-end talker. The flock allows for efficient sound undulate reflection, which is a key prerequisite for character cabinetwork in audio equipment.
The choice of timber for any project is a balance between aesthetic goals and physical realism. By receipt the substantial weight of zebrawood, artificer can amend prepare for the structural demands of their designs and the technical requirement of the build. From the initial sourcing of material to the final coating pelage, respecting the physical properties of this alien specie guarantee the seniority and mantrap of the resulting work. Proper plan regarding puppet alimony, structural support, and material manipulation allows for the successful desegregation of this arresting woods into recherche furniture that celebrates the inherent strength and weight of zebrawood.
- zebrawood woods coloring
- zebrawood forest for sale
- zebrawood hardwood
- zebrawood facts
- zebrawood species
- zebrawood boards for sale
